Installing Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2011, 02:50 PM   #1
Installing utility sink
I need to install a utility sink, and this is what I have access to:
Could someone tell me at what points to cut for hot/cold, and where to cut/put drain from sink.. any other tips would be useful too! (like how to turn off water lines beforehand)
I see with a pump like this:
I don't need to vent it.. so i am hoping it's very easy to install.
  • Laundry Tub Pump
  • 1/3HP 115V 60HZ motor
  • Fits under laundry tubs, vanities, wet bars and utility sinks
  • Designed for a maximum lift of 10 feet
  • Pump body Noryl corrosion resistant
  • Ideal for limited floor space
  • Thermal and overload protection
  • Allows sink installation without breaking concrete
  • No vent connection required
  • Capacity up to 1400 US GPH
krisbfunk is offline   Reply With Quote
Tags
drain pump , plumbing , utility sink , venting pipes
Repair Utility Sink in Basement lincolnparkjok Plumbing 5 08-04-2014 07:04 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 09:10 PM
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 09:23 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
