Installing A Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2011, 09:35 AM   #1
Installing a Utility Sink
I'd like to install a utility sink in a basement. The plumbing in the house is pvc so I think the drainage would be relatively easy.
The question that I have is related to distance between the drain on the sink and the main house sewage line. I assume that the sink drain needs to be higher than the clean-out. Is there a minimum distance that exists or as long is the sink drain is higher am I OK?
rslackde is offline   Reply With Quote
Installing utility sink krisbfunk Plumbing 0 02-13-2011 02:50 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 09:10 PM
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 09:23 PM
After Snaking, Basement floor drain and utility sink still Bubbling & Backup bikermark1 Plumbing 2 07-22-2010 01:14 PM
Washer drain pipe and adding a utility sink lubyone1 Plumbing 5 07-09-2010 11:56 PM
