Installing A Utility/laundry Sink Off Centered - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2011, 09:22 AM   #1
Installing a utility/laundry sink off centered
Hello, I want to install a utility sink in my basement but off centered if possible. If I install the sink centered to the plumbing coming out of the wall now, it will interfer with some cabinetry. Can I install it off centered (about 6 inches) without compromising the drain flow? Thanks!
jackie_ny is offline   Reply With Quote
Old 06-15-2011, 10:16 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 792
You should be fine installing off center of the drain.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 06-15-2011, 11:06 AM   #3
I just installed my utility sink.... My drain is about 6" off-center too, and it works fine.
Utility Sink with pictures!
Bloke is offline   Reply With Quote
Installing sink to vanity Philj Kitchen & Bath Remodeling 2 05-06-2011 06:21 AM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Installing a Double Sink ? Chuck0o0 Plumbing 4 10-08-2010 03:47 PM
Installing a pedestal sink on slate? britt_schaeffer Plumbing 2 09-28-2009 09:16 PM
installing a pedestal sink on slate? britt_schaeffer Tiling, ceramics, marble 5 09-23-2009 06:57 PM
