Installing Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2011, 03:20 PM   #1
Rewards Points: 248
Installing Tub
Hello, I was looking at replacing my shower in the basement with a tub/shower. However the drain is right in the middle of where the tub would go. Is it possible to put in tub there? Guess I'm not sure how the matching of the drain would work.
Thanks in advance
jburchill is offline   Reply With Quote
Old 06-08-2011, 03:32 PM   #2
DIY staff
Rewards Points: 7,174
You will need to open the concrete up to do that---After it's open moving the pipes is not usually to difficult.
Old 06-16-2011, 08:51 PM   #3
Rewards Points: 248
After I removed my shower. The side against the exterior wall is built out off of 2x4. that were on top of sheetrock which was sitting on 2x2 furrings...if that.makes sense.
Is it necessary to build the framing out with the 2x4's? or can the shower/bath be installed to the furrings?
Reason is I was trying to save some room.
thanks
Old 06-16-2011, 08:57 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can do that.
XXX
Installing Vinyl Siding ptarmigan61 Roofing/Siding 15 07-09-2015 03:02 PM
Installing a suspended in a room that has an angled wall... markronz Remodeling 10 02-20-2010 09:03 AM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
