Installing Toliet After Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2014, 10:43 AM   #1
Rewards Points: 83
Installing toliet after tile
I recently replaced my linoleum floor with tile but now the commode sits higher than it use to so I can't bolt it back on properly. HELP??
ttwin is offline   Reply With Quote
Old 02-06-2014, 10:50 AM   #2
Rewards Points: 13,296
Why not? Are the bolts to short?
Got a picture so we can see what your seeing.
Often times you just use a double thick wax ring or special shims on top of the flange.
Old 02-06-2014, 12:39 PM   #3
Rewards Points: 83
Originally Posted by joecaption
Why not? Are the bolts to short? Got a picture so we can see what your seeing. Often times you just use a double thick wax ring or special shims on top of the flange.
The bolts don't come up far enough once the toilet is placed on top of the wax ring. I had read about getting a couple of flange extensions and a thicker wax ring
Old 02-06-2014, 01:31 PM   #4
Rewards Points: 6,652
Did you use the existing bolts, or did you put in new bolts? As for the flange, take the toilet off and measure from the tile to the top of the flange, and post that measurement, along with a picture of the tape measure next to the flange, showing how high or low it sits, compared to finished floor (tile) level.
You can Get Closet Flange Extenders, if the existing flange sits too low below the finished floor level. This is one example. http://closetflangeextender.com/ Another kit at Lowe's http://www.lowes.com/pd_253209-138-436453_0__ The bolt kits you can also get at any hardware store, or Ace Hardware.
Old 02-06-2014, 04:21 PM   #5
If your trying to use the old bolts most likely they have been cut off.
plummen (02-06-2014)
Old 02-06-2014, 06:42 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Did you try sitting on the toilet to flatten out the wax a little bit?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-06-2014, 07:58 PM   #7
Rewards Points: 1,770
BY long brass tbolts and 2 wax rings.
Installing a tile fireplace hearth mlheath Concrete, Stone & Masonry 7 11-04-2012 10:50 AM
Installing Porcelain tile, complete guide? Total Sugar Flooring 5 03-07-2011 10:22 PM
Installing pre-hung door over tile to laminate transition aldgagnon Carpentry 5 10-26-2010 06:37 PM
Installing wood floors over saltillo tile Bloom Flooring 3 07-02-2009 11:42 PM
Old flooring / installing new vinyl tile gwelton Flooring 2 06-24-2009 04:10 AM
