Installing A Toilet Over Harwood Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2008, 11:20 PM   #1
Question
Installing a toilet over harwood floor
I am replacing an old toilet in one of my bathrooms. This room has hardwood floor. The old toilet was install over a ceramic base (1ft by 2ft). The new toilet is bigger than this base because of its shape. I was wondering if i could install the new toilet directly over the harwood floor and skip the ceramic base????? Thanks....
caglezs is offline   Reply With Quote
Old 02-06-2008, 11:57 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes you can, the wax ring makes the seal, so it should be fine.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-07-2008, 07:52 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
(HEY, RON! Hello!)
caglezs,
As long as the toilet base is flush and level with the finished floor, and not moving or rocking in any way, you're OK.
The flange should be on top of and bolted to the finished floor level with only the thickness of the flange itself above floor level, and then the toilet should be bolted to the flange in order for the wax ring to seal properly.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-07-2008, 10:42 PM   #4
Journeyman Plumber
Originally Posted by Mike Swearingen View Post
(HEY, RON! Hello!)
caglezs,
Mike
Hi Mike.
Good pointers given by mike.
Old 02-07-2008, 11:18 PM   #5
Longshot here but if nothing else, general information. Oatey makes two different white plastic plates - round bowl and elongated bowl - for use underneath a toilet. Their purpose is to help hide busted or missing tile and grout. If you need to conceal any shortcomings in the floor, one of these may help.
End Grain is offline   Reply With Quote
Old 02-08-2008, 12:23 AM   #6
Thanks for the pointers. I have installed the toilet already.
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 09:34 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
