-   -   Installing a toilet over harwood floor (http://www.diychatroom.com/f7/installing-toilet-over-harwood-floor-16714/)
caglezs 02-06-2008 10:20 PM
I am replacing an old toilet in one of my bathrooms. This room has hardwood floor. The old toilet was install over a ceramic base (1ft by 2ft). The new toilet is bigger than this base because of its shape. I was wondering if i could install the new toilet directly over the harwood floor and skip the ceramic base?????:( Thanks....
Ron The Plumber 02-06-2008 10:57 PM
Yes you can, the wax ring makes the seal, so it should be fine.
Mike Swearingen 02-07-2008 06:52 PM
(HEY, RON! Hello!)
caglezs,
As long as the toilet base is flush and level with the finished floor, and not moving or rocking in any way, you're OK.
The flange should be on top of and bolted to the finished floor level with only the thickness of the flange itself above floor level, and then the toilet should be bolted to the flange in order for the wax ring to seal properly.
Mike
Ron The Plumber 02-07-2008 09:42 PM
Originally Posted by Mike Swearingen (Post 95881)
(HEY, RON! Hello!)
caglezs,
Mike
Hi Mike.
Good pointers given by mike. :thumbsup:
End Grain 02-07-2008 10:18 PM
Longshot here but if nothing else, general information. Oatey makes two different white plastic plates - round bowl and elongated bowl - for use underneath a toilet. Their purpose is to help hide busted or missing tile and grout. If you need to conceal any shortcomings in the floor, one of these may help.
caglezs 02-07-2008 11:23 PM
Thanks for the pointers. I have installed the toilet already.:)
