Installing Toilet On A Concrete Floor, Can't Find A Flange That Will Fit Flush To The Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2010, 01:21 PM   #1
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor
How can I install a toilet on a concrete floor? It's a 3 in. pipe flush to the concrete. I can't find a 3' flange that will go inside the pipe and also fit flush to the floor. I can't use a flange that fits over the pipe because of the concrete. All the ones that fit inside the 3 in. pipe have a throat that flares out at the top and won't fit flush to the floor. If I use a spacer the toilet won't rest on the floor.
Last edited by Pete R.; 10-09-2010 at 01:31 PM. Reason: mis-spelled and missing words
Pete R. is offline   Reply With Quote
Old 10-09-2010, 05:33 PM   #2
Rewards Points: 150
If you have a 3in pipe comming thru the concrete you CAN'T us a flange that fits to the inside, it will cut down the inlet too much.
What you have to do is cut up enough concrete to get a outside flange to fit, sorry,
braindead is offline   Reply With Quote
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
Toilet Flange cody21 Plumbing 10 09-08-2009 02:31 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
toilet flange on concrete amakarevic Plumbing 4 07-04-2008 06:51 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
