Installing Toilet On Concrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2009, 11:36 PM   #1
oops
Installing toilet on concrete floor
I am concerned that installing my toilet directly on the concrete floor may eventually cause the toilet to crack. Does anyone have experience with this? Maybe toilets do just fine in contact with concrete.
I was thinking about placing thin rubber matting where the toilet makes contact with the concrete, but hopefully this is not really necessary.
diymaniac is offline   Reply With Quote
Old 12-14-2009, 05:50 AM   #2
Think about it. What is the difference between sitting on tile or concrete???
Old 12-14-2009, 10:52 AM   #3
A toilet was installed in my basement during construction for the workers to use instead of a porto potty. It's sitting on the concrete with a couple little spacers under where the screws are in the floor (like 1/4" gappers used for tile). It's been like that for 10 years and seems just fine.
As above it's about the same as putting it on concrete. If you put it on foam or rubber you might actually make it rock MORE then without those things. If your really concerned put it on a thin piece of plywood.
vseven is offline   Reply With Quote
Tags
cement , concrete , crack , toilet
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
getting rid of carpet > concrete floor > polish or stain? johnlvs2run Flooring 24 11-23-2010 10:31 PM
Damp Concrete Garage Floor Tom S. Building & Construction 15 03-27-2010 08:23 AM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
