Old 02-27-2012, 01:35 PM   #1
Installing toilet above horizontal above ground waste pipe
Hello,
I'd like to install a bathroom in my basement. My waste pipe however is 5 3/4 inches above the slab. This measurement is to the middle of the pipe. I'm looking into options such as wall mounted and rear discharge toilets, however I can't find any information on whether or not this would solve my problem.
Relocating the waste pipe below slab isn't a realistic option I'm afraid. Would anyone know if I could use a rear discharge toilet with a 90 degree drop directly into my waste pipe, or with a drop and turn at some type of angle.
Same questions re: the rear discharge toilet.
Any information would be appreciated.
Thanks!
Alex
alexlacelle is offline   Reply With Quote
Old 02-27-2012, 03:00 PM   #2
check the web for rear outlet toilets. they still make them and i have put a few in over the years. i think the outlet on them is only around 4 inches off the floor. the other option is a pump. you can sink the pit into the floor or get one that the tank is actually a small platform that the toilet sits on and flushes right into the tank. they also make toilets that flush up.
http://www.signaturehardware.com/class1661
http://www.plumbingsupply.com/sewage.html
http://www.saniflo.com/
http://www.naturalhandyman.com/iip/infplumb/infupf.html
http://www.accentshopping.com/ImageG...&IMG_Width=350
Old 02-27-2012, 03:25 PM   #3
Thanks for the info. I'm looking to stay away from any type of pump due to the noise. I've seen the rear discharge toilets, my question is can I go right from it to my waste pipe if the pipe is only a few inches below the discharge on the toilet?
Old 02-27-2012, 09:03 PM   #4
here is just one of them you will need a wall hung carrier "zurn is one manufacture" and thimble
http://www.build.com/crane-3217-elon...baid=762772953
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 02-28-2012, 07:52 PM   #5
I'm thinking a wall hung toilet, however my issue is that the vertical pipe after the 90 degree drop off the back of the toilet will be very short. I need to know if this will cause a problem or not?
Edit: I've attached a picture of the waste pipe over which I'd like to install the toilet.
Old 02-28-2012, 09:20 PM   #6
what is all connected to the drain line now and what size is it
Old 02-28-2012, 10:01 PM   #7
This pipe is the waste pipe for the entire house. Connected to it at one point or another is a full bathroom, kitchen sink, laundry tub and washing machine.
It's 3 inches in diameter.
I should add that right past the picture is where the pipe dips under the concrete and leaves the house.
Waste from other toilet? scottl31 Plumbing 22 11-18-2010 03:38 PM
Cutting into Cast-Iron waste pipe. dOe Plumbing 4 03-29-2010 07:09 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
