Installing A Standpipe Into The Basement Drain. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2012, 09:29 PM   #16
I was jumped six ways to sunday by everyone about making sure I put a trap in to prevent sewage gases. I tried explaining this was the basement drain, and therefore was open till now and if no one in the past 90 years complained I doubt it was an issue but....
There reason it ultimately went in was that it gave me the jog over from the drain on the tub to the drain pipe. I could have just moved the tub forward but I want to bolt it to the wall. The trap gave me the room to do so.
It appears I may be wrong, one of the neighbors said our pipes are iron (or steel) but were confirmed metal. Also confirmed it's not raw sewage, it's just storm water, basically the system locally gets overwhelmed and when the streets flood, it backs up into the houses.
And I agree I hope it never has to get tested.
Paradiselost is offline   Reply With Quote
Old 03-19-2012, 05:38 AM   #17
Rewards Points: 2,516
The basement drain already has a trap. I figured you used the trap on the sink to offset the laundry tub to line up with the floor drain.
Good luck.
hammerlane is offline   Reply With Quote
Flooring over basement floor drain BlueBSH Plumbing 8 09-30-2011 09:27 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Washing machine in basement drain pinkertonpv Plumbing 7 05-13-2010 07:58 PM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 03:46 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
