Installing A Stackable Washer Dryer In Hall Closet Next To Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2007, 11:31 AM   #1
Question
Installing a stackable washer dryer in hall closet next to bathroom
Hey guys,
I am installing a stackabe washer/dryer in a hall closet next to the batroom. I can have the gas and electric run my problem is how do I drain the washer? Its a second floor condo so I cant cut into the floor. It there a way to tap into the drain of the Sink or toilet so the washer can drain?
Thanks guys!
uncleb23 is offline   Reply With Quote
Old 10-03-2007, 01:36 PM   #2
Rewards Points: 150
IIRC by code, washer should drain via air gap, into a trapped and vented standpipe above its fill line. So yes, you should be able to cut into sink drain line.
Also be sure that dryer is adequately vented, and if gas, that combustion air is supplied. (will probably need a grill in the closet door)
scorrpio is offline   Reply With Quote
Old 10-04-2007, 08:51 AM   #3
Awesome thanks! Do you mean I can tap into it after the u-bend in the pipe? (sorry I'm a moron when it comes to this stuff..lol)
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 02:13 PM
Venting bathroom through dryer? phantoz HVAC 3 09-08-2007 12:53 PM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 10:31 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
