-   -   Installing a stackable washer dryer in hall closet next to bathroom (http://www.diychatroom.com/f7/installing-stackable-washer-dryer-hall-closet-next-bathroom-12064/)
uncleb23 10-03-2007 11:31 AM
Hey guys,
I am installing a stackabe washer/dryer in a hall closet next to the batroom. I can have the gas and electric run my problem is how do I drain the washer? Its a second floor condo so I cant cut into the floor. It there a way to tap into the drain of the Sink or toilet so the washer can drain?
Thanks guys!
scorrpio 10-03-2007 01:36 PM
IIRC by code, washer should drain via air gap, into a trapped and vented standpipe above its fill line. So yes, you should be able to cut into sink drain line.
Also be sure that dryer is adequately vented, and if gas, that combustion air is supplied. (will probably need a grill in the closet door)
uncleb23 10-04-2007 08:51 AM
Awesome thanks! Do you mean I can tap into it after the u-bend in the pipe? (sorry I'm a moron when it comes to this stuff..lol)
