Installing Slotted Perforated Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-15-2009, 05:00 PM   #1
Installing Slotted Perforated drain pipe
I am having some slotted perforated pipe installed to remove exess rain runoff from around my property. The guy installing it is insisting that it have a filter sock around it. Many people have told me that the filter is more likely to clog before the pipe, and that even if the pipe clogs it can be rodded. Once the filter sock is clogged, it has to be dug up and replaced.
Any help here is appreciated, he is due to start the project on Friday.
wetbasementjohn is offline   Reply With Quote
Old 07-16-2009, 07:23 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Personally, I would go with the filter sleeve.
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-16-2009, 08:46 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 590
Ayuh,... Agreed,.. It'll never Plug...
Bondo is online now   Reply With Quote
Old 07-17-2009, 10:23 AM   #4
RippySkippy's Avatar
The primary purpose of the sock is to keep certain soil types; fine loams, small sands from entering the pipe during back-fill and the initial settling. If water can move through the soil...it sure won't have any problems moving through a sock and it will not plug any quicker with than with out it. If the guy you hired says do it..do it...unless your intimately familiar with the soil properties around your place...go with the sock. Other wise do it yourself and learn from mistakes along the way
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 07-17-2009, 10:50 AM   #5
General Contractor
The guy doing the install is correct you do need the sock. There should also be gravel around the outside of the pipe to provide additional drainage.
ARI001 is offline   Reply With Quote
Old 07-17-2009, 10:58 AM   #6
Registered User
Termite's Avatar
At least 6" of gravel all the way around the pipe and a filter sock is pretty unbeatable.
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Can I connect toilet drain to this drain pipe james739 Plumbing 11 04-24-2009 08:06 AM
Vent requirement for laundry washer drain pipe WaldenL Project Showcase 1 01-12-2009 05:31 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 08:22 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
