-   -   Installing sink/cabinets in garage. (http://www.diychatroom.com/f7/installing-sink-cabinets-garage-20233/)
Emil 04-22-2008 08:13 PM
Hi guys,
I am in the plans to install a sink in my garage. I want to make it a sort of "mini kitchen," so I'll be using kitchen cabinets in the garage. I have some questions.
1st) Where I have the proposed project is where it has to go, there is no other room. There is a door between the project and the closest drain which is at the washer/dryer. Do I HAVE to have connect to a drain? I can just run a drain line into the wall and have it drain outside. I don't see another solution to the drain, since that door is in the way.
2nd) I have to connect to the water lines. Can I make the copper pipes go up and down, around the door jamb?
Tips, comments, critiques welcome!
I live in Southern, CA, so there is no worries about pipes freezing.
http://img.photobucket.com/albums/v1...77/Kitchen.jpg
I have included a link to a rough drawing I made up in paint.
Thank You,
Emil
Ron The Plumber 04-23-2008 08:48 AM
You have to connect to a drain, and you can route water lines how ever you like.
RippySkippy 04-23-2008 09:06 AM
Originally Posted by Ron The Plumber (Post 118418)
You have to connect to a drain...
Could it be connected to a drywell? IF the sink was used to wash things like fruits and veggies...and not full blown kitchen use were everything gets stuffed down the disposal. I'd guess Emil should talk to his local code enforcement people...but I'll bet your right.
Ron The Plumber 04-23-2008 09:29 AM
Yes talk to local building department for that info.
Emil 04-23-2008 07:31 PM
Thanks for the help. So with the laundry being too far away, how would I go about connecting to a drain? Am I totally out of luck?
RippySkippy 04-24-2008 07:16 AM
You could use a sewage ejector pump set into a vented pit, and pump the effluent your closest drain connection
Ron The Plumber 04-24-2008 08:02 PM
You could locate the sewer tie in a wye fitting, and run the line to it, vent it up and out and then get the water lines to there.
Emil 04-24-2008 09:14 PM
Great, thanks for the info. If I can't find a way to tie into the drain line, there is no point in installing a sink. Thanks again.
Mike Swearingen 04-24-2008 09:36 PM
If your home is over a crawlspace or basement, you should be able to tie into a drain. If you're on a slab, you may have to run it outside and then underground to a drain line.
Mike
