Installing Shut-off Valves - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-23-2011, 10:14 AM   #16
Thanks gentlemen. Looks easy enough. Last question. Since the pipes are close to the wall, I'm not sure if I'll be able to use a copper cutting tool because of leverage. I won't be able to fully turn it around the pipe. Should I just use a hacksaw to cut the pipe?
mjarema414 is offline   Reply With Quote
Old 12-23-2011, 10:20 AM   #17
Rewards Points: 2,512
You can use whatever you want BUT and I say BUT if you use a hacksaw you had better make sure you have a straight cut if using a compression fitting on that end.
hammerlane is offline   Reply With Quote
Old 12-23-2011, 01:59 PM   #18
Rewards Points: 558
Originally Posted by hammerlane View Post
No should look like this:
Sorry Epson
Heres a decent video from Brasscraft on how to install a compression fitting.
The video shows an angle shut-off. You would use a straight shut-off like the one pictured by myself or Epson. Just make sure when you start tightening the compression nut on the 1/2 copper that the valve itself does not turn at all during any of the tightening.
Haha ok mine is old and yours is a newer installation…
epson is offline   Reply With Quote
Old 12-23-2011, 02:07 PM   #19
Glad you saw the humor in it.
Old 12-23-2011, 02:11 PM   #20
Rewards Points: 558
We are all one big happy family here… Merry Christmas…
Old 12-23-2011, 05:34 PM   #21
Rewards Points: 81
Shark Bites and their clones makes shutoffs if you want to go that route.
Total Tool is offline   Reply With Quote
Old 12-24-2011, 12:53 AM   #22
Rewards Points: 558
How close are they? you can use a small tube cutter like this
or this one
The Following User Says Thank You to epson For This Useful Post:
plummen (12-24-2011)
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 10:47 PM
Installing shutoff valves syogod Plumbing 3 08-02-2011 11:17 AM
Help? Replacing water shut off valves frozenmama Plumbing 4 09-28-2010 07:17 PM
Do I need to raise my irrigation valve(s)? MrSmythe Landscaping & Lawn Care 3 09-03-2010 07:01 PM
No main power shut off vab53 Electrical 26 06-12-2010 03:51 AM
