Installing Shower Pan On Concrete Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2012, 11:27 AM   #1
Installing Shower Pan on Concrete Floor
I'm installing a Sterling shower system (pan and 3 walls) in a basement bath. Is there a shower drain that fits inside the 2 inch pipe coming up through the concrete? Or do I have to chip out around the pipe and use the conventional Oately drain that fits over the pipe? I'm talking about the one that has the rubber gasket that goes over the 2 inch pipe. Seems to me that the drain should be the male and the 2 inch pipe should be the female.
Steelfab66 is offline   Reply With Quote
Old 10-13-2012, 01:13 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No, the drain goes over the pipe.
When working with a shower base on a slab, it is critical that your drain location be very accurate.
The reason they don't make one that goes inside of a 2" is because 2" ID is the minimum size for a shower drain.
Good luck, and post back if you have more questions.
Journeyman Plumber
Old 10-13-2012, 01:37 PM   #3
if you put a coupling on a piece of pipe it becomes a female, put a piece of pipe in a shower drain and it becomes a male.
Shower floor repair pinkertonpv Kitchen & Bath Remodeling 18 08-23-2012 10:03 PM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 06:33 PM
Building a shower pan on a pre-sloped concrete floor tsg234 Kitchen & Bath Remodeling 1 02-06-2010 12:29 AM
Installing a shower pan--questions on concrete floor RuthL Building & Construction 14 07-21-2009 01:16 PM
installing a drain in a concrete floor monikakelly Plumbing 1 03-17-2009 01:17 AM
