-   -   Installing shower in basement (http://www.diychatroom.com/f7/installing-shower-basement-81466/)
jobblyman 09-14-2010 09:10 PM
Hello, I bought a shower kit. It comes with the base, walls, and door. I would like to install this shower in my basement utility/laundry room. The drainage down there is a four inch hole in the floor. There is a utility sink over it, with a drain pipe that just drops water into this drain. Next to the utility sink is the washer/dryer. The drain from the washer just drains into the utility tub, which drains into this hole.
Next to the washer/dryer I would like to install this shower. Am I able to build a platform for the shower, have its drain pipe slope at a particular pitch depending on the distance from the drain, and just have the water fall into this hole as the utility sink does? What about venting? Iím gathering no P trap is to be used since the floor drain already has one? I suppose plan B would be to dig up the concrete floor.
Thank you for the help/suggestions.
braindead 09-16-2010 04:04 PM
I think you have to go to plan B, the hook-up you have now is completly illegal! :no:
acerunner 09-16-2010 04:10 PM
i second plan b.
oh'mike 09-16-2010 06:53 PM
You will be happier with plan B--That will give you a chance to install a washer drain box,too,If you wish to modernize the whole area..
jobblyman 10-21-2010 11:20 PM
Thanks for the replies. Got held up and now getting back to the basement. Completely illegal?! My house was built in 1966 and there is just the floor drain in that room, which the utility sink and the washer use. I guess that was how laundry rooms were set up back in the day?
oh'mike 10-22-2010 06:21 AM
Post a picture ,if you can.----You have a freefall drain set up there---not illegal--used in restaurant kitchens all the time---However, your new shower will look like a funky temporary rig that will not add value to the house at all---
If a temporary,make due for now,quality of work suits the job---plan A
If you want the work to improve the house--Plan B
secutanudu 10-22-2010 06:43 AM
Doesn't each fixture require its own trap?
oh'mike 10-23-2010 05:57 AM
You know,that may be code in residences---I'd tear the floor open and do it right myself.
In a commercial kitchen several fixtures can share a free fall---I have never seen a free fall drain in a residence.
secutanudu 10-23-2010 05:59 AM
I'm not sure if it's code...but I've heard it mentioned here...
oh'mike 10-23-2010 06:24 AM
A funky installation like that will not improve the house--just drag the value down---
I like to do things right or not at all----------------
the_man 10-23-2010 08:53 AM
In my code, a shower cannot be run as indirect waste. Also, any indirect waste piping that is over 5' in length must be trapped regardless of where it drains
jobblyman 10-25-2010 10:24 PM
5 Attachment(s)
OK thank you again for the replies. It's nice talking DIY, as all my friends have children or condos so no DIY chat there. I tend to agree with Mike about doing things right, I just tend to also be cheap.
I finally have some photos together. The first photo is of the utility sink, with washer drain hanging off the side. The pipe on the bottom is from the AC and the humidifier drain. I believe this connects to the drop from the kitchen. From there it connects to the main stack. I'm not sure then how the water drains out of the house? I would think it goes out from the main stack, but then the chimney is over that path so I'm not sure. Perhaps it goes out towards the front from the drain under the utility sink? The utility sink is on the back wall.
jobblyman 10-25-2010 10:28 PM
new plans
3 Attachment(s)
Here is what I'm hoping to do. I would like the new shower in front of the washer and dryer. Then the pipe would go across the floor to under the washer and dryer location. I'm thinking from there branch out so I can have that washer drain outlet. From there connect to the main floor drain. In order for the utility sink not to drain into the floor, I'm thinking of tapping off of the kitchen drain and connecting the utility tub there? Any input, advice, criticism is greatly appreciated. Thanks again.
jobblyman 10-25-2010 10:32 PM
lastly
What about venting? Do I need to run a vent pipe over from the new shower to have it connect to the main 1 1/2" vent going out? That 1 1/2" vent connects in the attic to the large vent from the main waste stack.
Thanks again.
ultimatetouch 11-01-2010 08:27 PM
You should check with your local municipality on the codes. At least where I live anytime your doing a basement remodeling job or installing a new bathroom in a basement, you must install an ejector pit. Then you run your drains to the ejector pit and then it gets pumped overhead to a stack. Not only is this code in every town I have done work in but it will save your basement in the long run. If there is ever sewer back up there are no low spots for the back up to come out of.
_______________________________________________
