Installing Saniflo Macerator Pump Below Slab Level - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-02-2010, 05:30 PM   #1
Rewards Points: 508
Installing Saniflo macerator pump below slab level
Does anyone have any recommendations on how to build an enclosure or pit for my Saniflo macerating pump? I'm putting the pump below the level of the slab to avoid building a raised shower. I also intend put in a floor drain about 8' from this pump (floor drain, shower, and toilet will all drain to the pump).
benjamincall is offline   Reply With Quote
Old 02-02-2010, 06:00 PM   #2
Licensed Master Plumber
You can use a prefabed sump pit with cover. the big box stores sell them.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-02-2010, 06:21 PM   #3
Rewards Points: 508
The 18x30 poly tubs are a little big. Part of the reason I went with the Saniflo over a traditional ejector was to avoid taking up a lot of space.
Installing a slab exterior door kgressler Building & Construction 4 01-25-2009 01:56 PM
Installing solid bamboo over concrete slab Hetuck Flooring 3 12-21-2008 02:01 PM
Carpet on a sloped concrete slab? slickracer Flooring 4 12-13-2008 03:08 PM
Installing Interior Doors - slab jkrodger Carpentry 22 10-19-2008 07:22 PM
Installing Pedestal Sink on unlevel floor Manuel6 Plumbing 4 08-09-2007 09:31 AM
