Installing Saddle Valve On Hot Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2010, 04:06 PM   #1
Installing saddle valve on hot water pipe
I'm installing a new saddle valve on a hot water pipe for a feed line for a whole house humidifier. Do I need to shut off my main water supply valve when I do this, or just ensure no one places a demand on hot water until the work is complete? (I know I would shut off the main supply if I was installing on a cold water pipe, but am not sure if this would influence the pressure on the hot water side.)
I ask because my main system supply valve is a little touchy and I'd prefer to stay away from it if at all possible.
Any other steps I should consider regarding the pipe I'm installing it on, besides this issue? Thanks.
Dbizot is offline   Reply With Quote
Old 01-13-2010, 06:10 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
install the humidifier line on cold water side,youll be much happier!
plummen is offline   Reply With Quote
Old 01-13-2010, 07:05 PM   #3
Ok, but what will the difference be? I thought the h/w would aid the evap process, plus the existing valve for the humidifier I'm replacing is on the hot side (I can't reuse the valve - seized - old house I bought). But that's why I'm here, to get educated! Thx.
Old 01-13-2010, 08:06 PM   #4
plummen's Avatar
in all the years ive done them its always been on cold side just like icemaker lines.hot water lines tend to accumulate more crud ,which i think would tend to close off the valve easier.whichever side you install it on make sure to open/close valve a couple times throughout year to keep it from getting stuck as easy.
Old 01-13-2010, 09:21 PM   #5
firehawkmph's Avatar
Rewards Points: 1,902
Db,
The better saddle valves don't use the piercing needle point. They require a 1/4" hole be drilled into the pipe and have a rubber washer to provide a seal. These flow much, much better then the needle type.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-14-2010, 07:13 AM   #6
I am against the "needle piercing" valves. Also agree that the humidifier should be on the cold line. If you want to install on the hot line, all you need to do is turn off the cold water inlet valve at the water heater. Open a hot water faucet to relieve the pressure.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-14-2010, 11:11 AM   #7
Thanks for all the advice! Much appreciated.
can I runa second line from a pre-existing saddle valve? ClancyKev Plumbing 1 10-23-2009 06:02 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Hot water tank leaking from valve pipe bookingohio Plumbing 11 05-07-2009 09:43 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
