Installing A Roman Bath, Inside A Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2013, 01:01 PM   #1
Installing a Roman bath, inside a shower
Everyone says to NOT attempt a Roman bath as a first time tile project, and if I were sane, then I'd follow that advice. But sanity was never a strong point for me, so I wanted to ask you guys about this.
We live in Taiwan (I'm American) and just purchased a new house. They have tile showers but no baths and my wife wants a bath.
Given that the Roman bath would be built in the existing shower, I would think that waterproofing would be less of a concern. I'm considering building a wood frame in the rather large shower area. I'd like to use cement for the bottom, with pebbles embedded in the cement, and then tile the sides.
I need to see what kind of membrane they sell locally.
The tub wouldn't need to be plumbed in. The water in would come from the flexible shower hose and the outlet would be on the side, allowing the water to drain onto the shower floor and then down the shower drain.
Backup plan is to buy a tub here that just sits in and also doesn't get plumbed in.
I've got more free time than sense, so I don't mind playing around with it to get it right.
Crazy?
TaiwanGuy is offline   Reply With Quote
Old 09-24-2013, 04:10 PM   #2
The first thing that pops into my mind, if I understand you right, is there is going to be a fairly enclosed/dark/super moist area under your tub. MOLD??? Maybe you can deal with that possibility, but that sounds like a bad idea to me.
broox is offline   Reply With Quote
Old 09-25-2013, 01:25 AM   #3
It should be completely sealed, though. If things are done right, then no water should get under the tub.
Old 09-25-2013, 11:56 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
You plan on framing it out in wood, then CBU, then waterproofing, then tile?
Keep in mind that water weights, what... 8 pounds per gallon? Times how many gallons? That is a lot of pressure on your framing!
It might work, but it might collapse or develop leaks that would rot out the structure and mess up your shower.
I think this would require a bit more research on how strong this would have to be.
Old 09-25-2013, 07:04 PM   #5
Rewards Points: 1,692
Just use an Acrylic claw foot tub.
http://www.classicclawfoottubs.com/6...wfoot-tub.html
Installing New Bath Tub Up Against Exterior Wall greghamilton Plumbing 6 09-25-2013 01:47 AM
Installing sliding shower doors on a bath tub Bweatherbee Kitchen & Bath Remodeling 2 05-28-2012 10:35 PM
location of bath switches/ how far from shower mazey Electrical 2 06-29-2011 02:27 PM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Adding a shower to a 1/2 bath amyjean Plumbing 1 09-10-2005 08:06 PM
