Installing Reverese Osmosis Filter System - With A Garbage Disposal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2010, 01:36 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Installing reverese osmosis filter system - with a garbage disposal?
The istructions for my Wher25
Do not mention anything about intalling the system under a sink w/ disposal.
As you can see from the pic, there is a disposal here and then the plumbing continues below the floor where there is a drum trap in the laundry room downstairs.
I need to instal the drain adapter into the plumbing, however, I have no room presently to install the adapter piece -which is sitting on the floor over the cabinet in the picture. I have no idea how to do this... it's important to keep the drain line upright for gravity.
J187 is offline   Reply With Quote
Old 01-02-2010, 02:38 PM   #2
J187's Avatar
Rewards Points: 508
I realize it would fit if I could replace that PVC you see, with a 90 elbow and come over directly below the intlet of the disposal and then just run a short vertical piece and put the adapter inline there... but I don't know if that's exceptable to use 90s and all
Old 01-02-2010, 05:32 PM   #3
Mine is installed in the basement, up high near the ceiling
I drilled small hole & ran the tubing outside into my greenhouse
In warmer weather I fill a 55g drum for watering plants
I'd look into a connection in the basement for installation
Getting under the sink to change the cartridges is a PIA
Old 01-02-2010, 07:23 PM   #4
J187's Avatar
Rewards Points: 508
Interesting thought SD, thanks. I'll consider it...
As far as installing under the sink should I choose that route... I suppose I could use a saddle-drain kit on that long, slanted PVC you see in the picture, that should solve my problem no?
Old 01-03-2010, 08:57 AM   #5
J187's Avatar
Rewards Points: 508
I do think I would like to install this under the sink, at least for now - I will be redoing the room below the kitchen very soon...
Does anyone have any opinions on the saddle drain idea?
Old 01-04-2010, 01:09 PM   #6
J187's Avatar
Rewards Points: 508
Bump for opinions
Old 01-06-2010, 11:12 PM   #7
http://www.freshwatersystems.com/c-9...-adapters.aspx
kfosh is offline   Reply With Quote
Old 01-07-2010, 12:05 PM   #8
Rewards Points: 150
go to the same drain as the garbage disposer leaving a 2" air gap.that ftg.pictured is illegal to use in il.
rudolph58 is offline   Reply With Quote
Old 01-07-2010, 09:46 PM   #9
they pass here when used with the airgap built into the faucett that came with that ro system. there is a 1/4 red from reject that attaches to faucett airgap then the 3/8 black line off faucett airgap that attaches to drain in link or the one on photo.
Installing DWV system new construction joebart Plumbing 2 01-29-2009 08:45 AM
Sprinkler System - Installing Valve Box tazmajazz Plumbing 3 01-06-2009 10:14 AM
installing a split system Jacques HVAC 6 07-10-2008 09:50 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
installing whole house filter voodoo_chile Plumbing 2 02-03-2008 07:24 AM
