Installing Pot Filler - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2009, 04:06 PM   #1
Installing pot filler
How can I install a pot filler in an already renovated kitchen?
reno is offline   Reply With Quote
Old 04-12-2009, 04:19 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you have got to tell me what a pot filler is.
and, are you an electrician?
Old 04-12-2009, 04:27 PM   #3
A pot filler is a water supply faucet that is installed on top of the stove to eliminate carrying any heavy stock pots across the kitchen.
Old 04-12-2009, 06:48 PM   #4
HVAC / Plumbing
I think he's talking about a spigot over the range.. Like the chinese restaurant uses to fill the wok. You won't be able to make it look right without tearing out the wall behind the range. Unless, you want to run exposed lines up the wall behind the range.. Really hard to know how much trouble it would be without seeing it
kenmac is offline   Reply With Quote
Old 04-13-2009, 08:18 AM   #5
RippySkippy's Avatar
It all depends on what access you have to the walls, you may want to consider a deck mounted version.
Then again...it depends on your dry-wall skills...you could always whack out it out, replace and repair. Not a big deal if it's behind the stove. Do you have a backsplash in the area you want to install it?
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 04-13-2009, 09:53 AM   #6
Remodeling Contractor
You still have to carry the pots back to the sink to drain, but these are handy to add water while cooking. The piping is in the wall behind the faucet and you will need access from the back of this wall in order to make a secure connection to the ell going through the wall to support this faucet. The nipple sticking out the finished wall (3/4") should be centered on the stove and 16" high.
Method for installing 3/8" engineered hardwood poolecw Flooring 10 10-31-2008 03:10 PM
do not use concrete filler to fill stones... KUIPORNG Landscaping & Lawn Care 4 08-29-2008 04:16 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 08:26 PM
Recipe for woodfloor filler? bayoudonnie Flooring 1 08-22-2007 06:19 PM
Pot filler length wbjdmd Plumbing 2 11-09-2006 06:20 AM
