Installing A Plumbing Vent On A Basement Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-18-2012, 11:17 AM   #1
Installing a plumbing vent on a basement bathroom
Hi there,
I'm new to the forum and have a plumbing question.
I'm installing a bathroom in my basement - the builder had originally installed a 2-piece rough-in which I am taking out and replacing with a 3-piece bathroom (toilet, shower and sink).
I've broken the concrete floor and exposed a five foot section of the 4" PVC pipe. The upstream end of this pipe is fed by a bathroom on the 2nd floor.
When the builder had installed the 2-piece rough-in, he had installed a tee-wye on this section of PVC. Feeding into the wye was the toliet rough-in and a 2" vent pipe, which came out from the wye below the concrete and then vertically up the adjacent wall. Feeding into the vertical part of the vent is a 1.5" sink drain.
My questions is this: I will cut the PVC and remove a 3 foot section. At the downstream end, I'll install the rough-in for the toilet - a sanitary tee and 3" ABS coming up to connect the flange. At the upstream end, I will rough in the shower drain and connect the air vent just slightly downstream from the shower drain. Do I need to connect another vent for the toilet, or can I get away with just the one vent?
Any help is appreciated.
Breadmaker is offline   Reply With Quote
Old 09-18-2012, 02:50 PM   #2
a drawing or pictures would help a lot.
Old 09-18-2012, 03:28 PM   #3
Here is a quick sketch - hope it helps.Installing a plumbing vent on a basement bathroom-basement-bathroom-rough-.jpg
Old 09-21-2012, 12:22 PM   #4
Any suggestions from anyone?
Old 09-21-2012, 09:18 PM   #5
1) A general rule according to IPC code is as long as a fixture is within 8ft of linear pipe it will be properly vented
2) Your vent needs to be at least 2 in i.d. to provide the needed amount of air
3) I cannot tell if you drawing is oriented vertically or laid down horizontally, san-tees CANNOT be laid on their sides or on their backs! In this situation a wye or combination fitting must be used!
4) ABS AND PVC ARE NOT COMPATABLE! I highly recommend you keep materials consistant.
5) All rubber couplings must be of the type with the sheilded bands, and tightened to the specs of the given coupling
okieplumber is offline   Reply With Quote
basement bathroom plumbing - water in trench donnyt23 Plumbing 7 03-08-2012 12:14 AM
Plumbing a basement bathroom stradt03 Plumbing 15 11-20-2011 06:41 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 11:50 AM
Basement bathroom under slab plumbing garynlisa Plumbing 0 02-01-2010 11:04 AM
pre-stubbed basement bath vent needed? ameleus Plumbing 7 09-21-2008 11:26 AM
