Old 12-20-2011, 12:33 AM   #1
Installing Plumbing in a basement with No rough ins
My wife and I are starting to make plans to finish our unfinished basement. In doing so, we want to add a bedroom and a bathroom for our family to expand. There is currently NO rough in plumbing, so I thought I would attack this problem in one of two ways. One, I could build the floor up to accommodate for drainage, or two, I could cut the concrete for drainage. Either way, I know I'm going to have to install a grinder pump to expel the waste. Are there any suggestions on which route I should take? Building the floor up would be easier, but my gut tells me I should cut the concrete.
Thanks,
Matthew
simpsjm1 is offline   Reply With Quote
Old 12-20-2011, 07:07 AM   #2
Super Moderator
Cut the concrete it's the only way to do it right.
We have walked a lot of homeowners through the process---when you are ready,someone here will help with layout and the mechanics of the job.
Old 12-20-2011, 08:04 AM   #3
hi matt yes building floor up is eaiser....but its just not right.....iwould suggest to cut concrete ...there only one way the right way....even if is is more work...ben
Old 12-20-2011, 08:23 AM   #4
BIGRED
Hi Matt,
You also mentioned having to add a grinder pit for waste removal in your basement. Do you know that you have an overhead sewer? Depending on your home's existing sewer line exit you may only need to tie into the 4" line (if it is under the concrete), but yes the job is much neater, safer, and more sanitary under the slab. Grampa Bud
Grampa Bud is offline   Reply With Quote
Old 12-20-2011, 11:26 AM   #5
firehawkmph's Avatar
Matt,
If you don't want to cut the floor you can use one of these:
http://www.homecenter.com/ProductDet...id=130507&fd=8
The unit can be mounted behind the stud wall so it is hidden.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-20-2011, 09:14 PM   #6
Waiting for an answer on whether you can gravity flow out or not. If so, I guess I would snap lines for your bathroom layout and just cut out the room so the cuts will be under the walls. So if you have a 5x8 bathroom, your lines would be cut at 61 3/4" and 97 3/4". Do the plumbing and re-pour the concrete.
As with many endeavors, the most difficult part is getting your mind around it.
If you plan any other plumbing, such as laundry, water softener, floor drain, HVAC drain, utility sink, try to get this in adjacent to the bath.
cleveman is offline   Reply With Quote
Old 12-20-2011, 10:32 PM   #7
I am attaching an image of the layout I have designed for the basement. Directly to the right wall between the bathroom and the storage area is the drain line that flows directly into my septic tank. That drain line is 79 inches from the concrete floor to the line (just next to the main beam supporting my upstairs), so I have to have some way to pump up to it. The only things I will want to pump up is the bathtub, toilet, and sink for the bathroom. Then, I'd like to add a sink over in the bar area. If interested, I designed the layout on my iPad using Home Design HD.
Thanks for all the advice thus far.
Old 12-20-2011, 10:42 PM   #8
So I suppose you want your toilet to be the low point, leading to a tank or something. I would find out about the pump & tank system and design around it.
Old 12-20-2011, 11:40 PM   #9
call me E
TheEplumber's Avatar
Very doable. Put the pump in the storage room, saw cut to the bathroom and plumb to your hearts content.
Two things to consider- 1. how to vent the pump and fixtures. 2. Install a door to the storage/hvac area
Tags
basement bathroom, plumbing
How to - prevent basement mold crazymountain How To Guides 31 01-20-2012 08:59 PM
Could use advice regarding plumbing for a basement bathroom raaczb Plumbing 3 01-22-2011 01:22 PM
Basement Bathroom - plumbing thoughts (pics) rkerns Plumbing 1 01-12-2011 05:14 PM
Plumbing in Basement osajia Plumbing 7 12-08-2010 01:00 PM
can anyone identify this mystery basement plumbing??? pkovo Plumbing 6 03-08-2009 11:20 PM
