Installing Plastic Toilet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2012, 01:57 PM   #1
In a little over my head
Rewards Points: 706
installing plastic toilet flange
I seem to have gotten myself a little confused.
All this is new construction.
All the DWV was installed before the floor and walls. Vertical pipe to the toilet is 4" PVC. It was cut long and has been sticking up thru the subfloor as construction progressed. Now I'm up to laying the CBU and tile. I have a Souix Chief 886-4PTM that will fit over the 4" pipe (and has been serving as a cap). Looking at it now, I se that the hole in the plywood is just right for the 4" pipe, but too small for the hub on the flange. I'm not exactly sure how to cut the hole bigger, since the pipe's in the way. Suggestions? And, how high should the vertical waste pipe be cut off, relative to the CBU?
Thanks!
ratherbefishing is offline   Reply With Quote
Old 06-16-2012, 02:30 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 802
Run a sawzall around the outside to cut away the plywood(not damaging the pipe) or buy a flange that fits inside the 4"
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
Toilet Flange Inside or Outside Drain Pipe? sledged Plumbing 23 01-18-2012 12:18 PM
Installing new toilet - flange question ncstevem Plumbing 7 12-18-2010 05:45 PM
Replacement toilet flange for Iron rgb407 Plumbing 9 08-27-2008 07:40 PM
