Old 02-26-2008, 09:30 PM   #1
installing pex.
I am installing pex in a bathroom and laundry room remodel. Do you still need an air chamber at every fixture?
Bcoleman6 is offline   Reply With Quote
Old 02-26-2008, 10:00 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
installing pex.
If code requires it.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-26-2008, 10:23 PM   #3
installing pex.
My city is on the 2006 code. Is there a free online version where I can look it up as with the NEC? Can't find one when I do a search.
Old 02-26-2008, 10:25 PM   #4
Journeyman Plumber
installing pex.
What state?
Plumbings State Codes online are rare to find, check local library of call you bldg dept and ask them.
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 09:09 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 11:26 PM
