Old 08-07-2007, 08:24 PM   #1
Installing Pedestal Sink on unlevel floor
I am finishing the remodeling of my bathroom, and I am installing a pedestal sink. I roughed in the drain and supply lines exactly where I wanted them, and now all that is left is the installation of the lavatory. I tried to install the lavatory today; however, much to my dismay the floor was unlevel and the pedestal base rocked too much (between 1/8 & 3/16" out of level, by the way). I decided to quit and think about how I was going to level the lavatory. I was able to level the base with some plastic toilet shims; however, the pedestal, to the eye, now looks cocked, even though it is in fact level and plumb.
My question is the following: Is there a way to level between the lavatory itself and the base? If I am able to do that, then I can at least leave the base flush with the floor and any gap between the lavatory and the base would not be as noticeable to a person of average height. Also, if shimming at the lavatory bottom is possible, what shimming material should I use, I imagine some type of rubber of foamy material.... Thanks in advance. This is a great forum!
Manuel6 is offline   Reply With Quote
Old 08-07-2007, 08:53 PM   #2
Remodeler
MinConst's Avatar
Kind of a cobby way to do something but you might build up with epoxy on the top of the pedestal. You could build a form from something flexible and fill with epoxy. Once hardened you could sand to the shape and taper you need.
If you make a form line it with saran wrap.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 08-08-2007, 07:32 PM   #3
Union HVAC Tech.
Most of the guys I work with shim the base to the floor with flattened copper tubing and then fill the gap with plaster of paris or floor grout.
bigMikeB is offline   Reply With Quote
Old 08-09-2007, 09:14 AM   #4
Thanks for the responses guys. I guess the bottom line is- shim the base- which is fine with me. And it probably makes the most sense.
I have a follow-up question. The base that I have does not have the pre-drilled holes to accept lag screws. I imagine that it is a base that is simply caulked down. However, I don't feel comfortable simply caulking down a base that is going to be shimmed, for the caulk may not make full contact with the floor in some areas. I was thinking about making a brace that I could use to tie down the base from the inside (the base has a gap cut out that would allow this) that would be attached to the floor. What do you think about that? In end, my thinking is that it would be comparable to shimming a toilet; you shim the toilet level, and then you tighten the commode down onto the shims slowly. Any advice would be appreciated. Thanks.
Old 08-09-2007, 10:31 AM   #5
I got similar problem with my Pedestal Sink installation, I just shim the pedestal at the center with some remaining laminate flooring pieces being wrap with plastic covering (avoid water damage), as the shim is inside, the end result is the Pedestal looks like risen up from the floor, but it is holding strong. Wife didn't complain at all... whether you like like the look of the Pedestal being hold up in air is personal opinion, but I am'nt going to bother with it as wife didn't complain..... another thing, I didn't have any fastening to the pedestal at all.. it just hold and stand by the upper/lower compression force.... I believe only earth quark can knock it down... I don't want to fasten it because in case need to do some plumbing work, it can be remove easily....
KUIPORNG is offline   Reply With Quote
More On This Topic
Ok, so, now all we have left to do, is get our bottom board in. And, what we'll do is, we'll just take this whole door off, see if that will give us enough room, for this to slide in. (Cough) Excuse me. Now, put our hinges back on. And, there we go. OK... Read More »
We are doing a kitchen remodel, and we’re installing the sink. We have replaced one of the supply lines, we have the sink in, and the supply line is connected to the outlet valves. Now we’re going to install a dishwasher drain. You put it on... Read More »
My name is Jeff Pence. I am with Bob Street today from Houdini Home Improvement in Lebanon, Ohio on behalf of Expert Village. In this clip, we are going to be unpacking the pedestal sink and going over some of the tools and extra supplies that are going... Read More »
Once you get all of your plumbing in. Now on this sink, the drain is set forward from the drains coming out of the sink because of the remodel. This inlet right here is going to go to the dishwasher on this side of the sink. We had to use a flexible hose... Read More »
How to Caulk a Kitchen Sink
How to Caulk a Kitchen Sink by Expert Village
Once you have all the plumbing done and all the water connected up, you want to take some 100% latex silica caulking, and press it hard up against the edge of the sink. Let it get everywhere. Make sure you press it up against the sink really hard. Once... Read More »
Installing Laminate over uneven pine plank floor? tomzpc Flooring 6 04-16-2008 09:07 AM
Pedestal Sink epolgar Plumbing 5 07-31-2007 04:21 PM
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 1 04-22-2007 01:32 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
