Installing Out Door Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2008, 04:00 PM   #1
tomhagg
installing out door tap
Hi,I am thinking about installing a outside tap attached to house
not sure on how to go about it,any help would be most welcome.
tomhagg is offline   Reply With Quote
Old 03-17-2008, 04:54 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Well what type of pipe is in the house now?
Where is the closet point of connect at?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-17-2008, 05:31 PM   #3
tomhagg
closet point of connect is under sink not sure what size of pipe
Old 03-17-2008, 05:37 PM   #4
Journeyman Plumber
You have to know the path your going to take, to where you want this to be at, this is the 1st step.
Once to know this then you make a connection by adding a tee on the cold water line, then running the line to the location to be, then adapting to the line to make up the hose connection.
Is there no crawl space under house?
Old 03-18-2008, 02:19 AM   #5
I blame ProWallGuy
Rewards Points: 150
Also, what type of pipe is it? Lead, steel, copper, plastic?
Double A is offline   Reply With Quote
Old 03-18-2008, 12:07 PM   #6
tomhagg
there is no crawl space under the house,I am going to run the pipe along
the wall to the front of the house and connect tap there, then I will be able to wash my car,as for the pipe it is copper.
ps thankyou very much for all replys.
Old 03-18-2008, 07:21 PM   #7
Journeyman Plumber
So now you have to connect a tee onto the copper and run your line to the hose location, I'd use pex if it was me. Do you know anything about plumbing and all?
Old 03-19-2008, 01:25 PM   #8
tomhagg
I have some knowledge of plumbing not much.But I now have a little
start for my project thanks to you guys,I have found out that my pipe
is 15 m and have bought my brass tap and 15m copper pipe now I have to buy a tee some plumbing tape and try and get the job done will let you guys see pics when finnished.
once again thankyou for all your help.
Old 03-19-2008, 02:53 PM   #9
I blame ProWallGuy
Rewards Points: 150
Good start.
Have you considered how you will protect this new tap and its supply from freezing weather?
Old 03-20-2008, 02:23 PM   #10
tomhagg
Hello guys,managed to get my tap up and running,with a good deal of help from you all at this very good forum,will post pic tomorrow.
Old 03-21-2008, 11:58 AM   #11
tomhagg
Hi guys,managed to install tap with good results,I planned on inserting an image but I cant seem to upload the 2 pics I have of the job,when I click on image nothing happens.
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 06:19 AM
Installing T&G birch ceiling NeedHelp Building & Construction 6 12-29-2007 08:09 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 12:59 PM
Installing Corner Countertops on a corner that is not square? tjandt Remodeling 10 12-30-2005 10:26 PM
