-   -   installing out door tap (http://www.diychatroom.com/f7/installing-out-door-tap-18637/)
tomhagg 03-17-2008 04:00 PM
Hi,I am thinking about installing a outside tap attached to house
not sure on how to go about it,any help would be most welcome.
Ron The Plumber 03-17-2008 04:54 PM
Well what type of pipe is in the house now?
Where is the closet point of connect at?
tomhagg 03-17-2008 05:31 PM
closet point of connect is under sink not sure what size of pipe
Ron The Plumber 03-17-2008 05:37 PM
You have to know the path your going to take, to where you want this to be at, this is the 1st step.
Once to know this then you make a connection by adding a tee on the cold water line, then running the line to the location to be, then adapting to the line to make up the hose connection.
Is there no crawl space under house?
Double A 03-18-2008 02:19 AM
Also, what type of pipe is it? Lead, steel, copper, plastic?
tomhagg 03-18-2008 12:07 PM
there is no crawl space under the house,I am going to run the pipe along
the wall to the front of the house and connect tap there, then I will be able to wash my car,as for the pipe it is copper.
ps thankyou very much for all replys.
Ron The Plumber 03-18-2008 07:21 PM
So now you have to connect a tee onto the copper and run your line to the hose location, I'd use pex if it was me. Do you know anything about plumbing and all?
tomhagg 03-19-2008 01:25 PM
I have some knowledge of plumbing not much.But I now have a little
start for my project thanks to you guys,I have found out that my pipe
is 15 m and have bought my brass tap and 15m copper pipe now I have to buy a tee some plumbing tape and try and get the job done will let you guys see pics when finnished.
once again thankyou for all your help.
Double A 03-19-2008 02:53 PM
Good start.
Have you considered how you will protect this new tap and its supply from freezing weather?
tomhagg 03-20-2008 02:23 PM
Hello guys,managed to get my tap up and running,with a good deal of help from you all at this very good forum,will post pic tomorrow.
tomhagg 03-21-2008 11:58 AM
Hi guys,managed to install tap with good results,I planned on inserting an image but I cant seem to upload the 2 pics I have of the job,when I click on image nothing happens.
