Installing New Utility Tub In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2008, 07:55 PM   #1
Unhappy
Installing new utility tub in basement
Hi, we own a 1958 home in Ohio. We recently ripped out a basement "concrete" utility tub, which was located next to the washer and dryer. The washer drained it's discharge into this tub. The utility tub then had a black flexible hose that ran from the tub to a hole in the concrete, which appears to be a drain with no cover. Also, the "hole" has another pipe that comes from the water heater, and drains into it.
Our question is whether we can just re-create the same set-up for the new "lighter" utility tub? We would like to do everything up to code, so as to not incur expenses later for re-sale. Any helpful tips or feedback?
lilerm8302 is offline   Reply With Quote
Old 10-18-2008, 08:53 PM   #2
Your house was built in 1958. I am sure that was acceptable back then. No one expects you to chip up the concrete to set it up the way that it should be with a real drain.
You will be fine if that is the way it was when you got the house.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-18-2008, 10:48 PM   #3
Guessing that the "hole" is a floor drain with no cover. This is typical. I would say to go ahead and run the new set-up the same way.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-19-2008, 01:52 AM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If you want to get everything up to code then you cannot recreate the same setup you just took out. A proper drain and vent for your utility tub needs to be installed.
JDC is offline   Reply With Quote
Old 10-19-2008, 08:08 PM   #5
Thanks to all!
It has been done! It might not be up to code, but it's the same way it was before the tear down.
Old 10-20-2008, 04:50 AM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
LoL....I kind of figured you'd scab it back together even though you stated in your original post that you wanted to keep everything up to code. Congrats!
Do I need a vent on a basement utility tub? skipjack Plumbing 7 09-05-2008 06:57 PM
Installing a utility sink BNPadgett Plumbing 1 05-03-2008 09:49 AM
basement utility sink install bjkPoker Plumbing 2 03-18-2008 07:12 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
