-   -   Installing new utility tub in basement (http://www.diychatroom.com/f7/installing-new-utility-tub-basement-30172/)
lilerm8302 10-18-2008 07:55 PM
Hi, we own a 1958 home in Ohio. We recently ripped out a basement "concrete" utility tub, which was located next to the washer and dryer. The washer drained it's discharge into this tub. The utility tub then had a black flexible hose that ran from the tub to a hole in the concrete, which appears to be a drain with no cover. Also, the "hole" has another pipe that comes from the water heater, and drains into it.
Our question is whether we can just re-create the same set-up for the new "lighter" utility tub? We would like to do everything up to code, so as to not incur expenses later for re-sale. Any helpful tips or feedback?
Marvin Gardens 10-18-2008 08:53 PM
Your house was built in 1958. I am sure that was acceptable back then. No one expects you to chip up the concrete to set it up the way that it should be with a real drain.
You will be fine if that is the way it was when you got the house.
majakdragon 10-18-2008 10:48 PM
Guessing that the "hole" is a floor drain with no cover. This is typical. I would say to go ahead and run the new set-up the same way.
JDC 10-19-2008 01:52 AM
If you want to get everything up to code then you cannot recreate the same setup you just took out. A proper drain and vent for your utility tub needs to be installed.
lilerm8302 10-19-2008 08:08 PM
Thanks to all!
It has been done! It might not be up to code, but it's the same way it was before the tear down.
JDC 10-20-2008 04:50 AM
LoL....I kind of figured you'd scab it back together even though you stated in your original post that you wanted to keep everything up to code. Congrats!
