Installing New Tub, Drain Location Change. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2012, 02:09 PM   #1
Installing new tub, drain location change.
Installing new drop-in tub. New tub drain will be a couple feet from old drain. Can I run a vertical pipe over to where old conncetion was near the trap? Is this OK or will it cause problems?
RonaldS is offline   Reply With Quote
Old 02-17-2012, 02:51 PM   #2
Rewards Points: 660
Do you mean horizontal? Where is this tub located in the house? Why can't you move the trap to its new location?
B
Beepster is offline   Reply With Quote
Old 02-22-2012, 09:37 AM   #3
Yes horizontal. I thought it would be easier than moving the trap.
Old 02-22-2012, 09:40 AM   #4
Tub is on second floor. I have not removed old tub yet. I think I would need to run horizontal pipe through floor joists.
Old 02-22-2012, 09:50 AM   #5
DIY staff
Rewards Points: 7,174
Trap must be moved to the tub drain location---
A trap down line in a horizontal pipe is called a 'running trap'--illegal--and a real trouble maker--
If you did that you would have constant problems with sewer gas and clogged up drains--
Move the trap,too.
ben's plumbing (02-22-2012)
installing a roof drain -BUR drbracken Roofing/Siding 6 12-02-2010 10:33 AM
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
proper location of outside drain tile 4just1don Building & Construction 3 08-30-2009 10:16 PM
Installing a french drain chatterbass Building & Construction 5 10-23-2008 07:35 AM
