Installing New Toilet Over Old Rusted Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-02-2013, 09:35 AM   #16
Rewards Points: 1,216
Originally Posted by joecaption View Post
The outside of the repair flange is bigger on the outside, the inside where the slotted holes are is the same bolt pattern as the old flange.
Don't look like much of a bolt pattern on the CI flange. I say just use new screw bolts in the same holes that held the base down to start with.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 08-02-2013, 07:33 PM   #17
Rewards Points: 1,952
Buy 2 long tbolts and then cut the tbolt off with a hack saw. Avoid messing the thread up.
Screw the tbolt into your flange I can see the holes in your picture.
Screw a locking bolt directly ontop of your screw so it will hold it securely.
Buy a nice real thick jumbo wax ring
Set your toilet
Then install your plastic hold downs and washer then bolt her down..
You should feel your wax compress as you set the toilet..
Have a great day.
It wouldn't hurt to clean your flange with pine oil cleaner and a wire brush first..
The only problem with a repair flange is it will not make an air tight seal and you may smell the sewer later...
The Following User Says Thank You to Ghostmaker For This Useful Post:
COLDIRON (08-03-2013)
Toilet flange question clambake6 Plumbing 18 03-07-2013 09:25 PM
Help with old, rusted cast iron toilet flange BigWinston Plumbing 7 08-08-2012 09:02 AM
en Flange bolt. Not sure how to proceed. latenight Plumbing 4 08-07-2012 05:01 PM
toilet flange question donkeyk Plumbing 15 02-01-2012 06:46 PM
rusted toilet flange removal? Boughamer Plumbing 4 07-06-2008 06:44 PM
