Installing A New Toilet Flange - Before Or After Tiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 01:51 PM   #1
Installing a new toilet flange - before or after tiling
I have a 4" stub for the new toilet. Should I wait to cut it off until after I put the tile down?
WoodmanFL is offline   Reply With Quote
Old 01-21-2012, 02:24 PM   #2
MarginallyQualified
Rewards Points: 2,464
tile --> grout --> set flange --> set fixture
Old 01-21-2012, 03:11 PM   #3
Rewards Points: 150
Are you tiling ontop of the concrete slab?
1) Dry-fit flange and install tile
2) Grout
3) Install flange, anchor to concrete
4) Profit
5) Install toilet.
psilva8 is offline   Reply With Quote
Old 01-21-2012, 03:34 PM   #4
DIY staff
Rewards Points: 7,174
I prefer to set the flange to the concrete and tile around it---Here's why--
No need to drill through the porcelain tile--no possibility that the flange will be to high and hit the bottom of the toilet ---
I do bathrooms---flush to the tile has never been a problem--but on top of the tile has been on many occasions.
You must decide---most books will tell you to place the flange on top of the finished floor--
I speak only from personal experience--Mike---
Old 01-21-2012, 03:36 PM   #5
my vote is for on top of the tile
broox is offline   Reply With Quote
Old 01-21-2012, 03:53 PM   #6
Rewards Points: 1,770
Here we go again; the on-top or level debate. Last time the winner was level if I remember correctly.
bob22 is online now   Reply With Quote
Old 01-21-2012, 03:56 PM   #7
DIY staff
It never ends----
Old 01-21-2012, 04:00 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 904
I vote for on top.
And in your case it looks like you'll need an inside flange
Old 01-21-2012, 08:06 PM   #9
Rewards Points: 582
the debate never ends...on the concrete..or on the tile... you decide either way it will work...
Old 01-21-2012, 08:29 PM   #10
Master Plumber
Javiles's Avatar
Rewards Points: 996
On the tile on the tile on the tile on the tile no no wait on the cement on the cement the cement on no wait the tile……….
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 08:16 PM
Labor/material costs for replacing toilet flange SpookyLugBolt Off Topic 0 07-21-2010 09:08 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
Problem toilet flange dougm Plumbing 5 11-22-2008 07:32 PM
