Installing A New Shower Unit - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2008, 08:31 PM   #1
installing a new shower unit
The manufactory says to install a pad under the base if installing on concreat. Are they talking about vinyl? vinyl flooring.
randy
randys is offline   Reply With Quote
Old 10-14-2008, 10:55 AM   #2
I read your other post stating that the reason for a pad is to prevent squeaking. This makes no sense, since the base should not move at all once installed. Only "pad" I am aware of under a shower or tub is a mortarbed. This is mortar poured under the base to prevent the bottom from flexing when someone enters it. Plastic sheeting is laid down for moisture protection and then pre-mixed mortar is piled under the base and then the base set into it and secured.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Installing a Shower Blaze25 Plumbing 2 10-13-2008 07:32 PM
Installing a shower pipe (again) donvier Plumbing 14 02-04-2008 09:06 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 08:23 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 08:26 AM
