Old 02-11-2013, 10:23 PM   #1
Installing New Shower - Multiple Questions
I'm installing a shower. I'm installing it where a tub use to be. The concrete floor was flat so I installed a sloped floor with Sand Mix and created a ¼" per foot slope. I then installed a liner. Now my first issue is, I installed the Hardy Back and now in one corner, the Hardy Back is not flush to the wall due to the fold of the liner in the corner. So now do I need to float the entire corner up to the ceiling to correct it or is there a trick I'm missing or did I do something wrong?
timidir is offline   Reply With Quote
Old 02-11-2013, 10:49 PM   #2
First post a picture of what you have now.
Second, did you change the drain to 2". A shower needs a 2" drain.
Old 02-11-2013, 10:51 PM   #3
Super Moderator
You should have tucked the fold into the open stud bay----what did you do?
Old 02-11-2013, 11:00 PM   #4
"joecaption"… took a few pics… as soon as my iCloud decides to put them in my photo stream on my computer, I'll post. As for the drain, luckily they had reduced from 2" to 1-½" for the tub, so yes I was able to make it 2" with p-trap.
"oh'mike"… I had king studs in the corner so I just folded against them. I didn't think of that. Maybe I'll take that piece off and try and re-fold it in between the studs. But now thinking… not sure I could do that and make it across a couple of studs to get to the open bay with out screwing up the corner of the floor.
Old 02-11-2013, 11:13 PM   #5
Here's a couple pics...
Installing New Shower - Multiple Questions-photo-3.jpg   Installing New Shower - Multiple Questions-photo-1-1.jpg
Old 02-12-2013, 09:54 AM   #6
Doing it myself
Alan's Avatar
Did you test the pan before proceeding? Just checking.
Journeyman Plumber
Old 02-12-2013, 07:19 PM   #7
I did...
The Following User Says Thank You to timidir For This Useful Post:
oh'mike (02-12-2013)
Old 02-14-2013, 12:33 AM   #8
Jack of all Trades
lifestooshort81's Avatar
Hate to make ya do it but if you want a flat wall you'll have to. Pull the backer board down around the area that of concerd. Using a sawzall, hand saw, hiring a local beaver or your teeth, notch out the stud just enough to be able to tuck the liner against. I'm assuming the stud is not load bearing but you have to be the judge of that. I'm a kitchen/bath contractor and encounter this all the time. That's how I usually do it when I encounter what you have.
Best of luck! Any other q's shoot away hopefully well be able to answer!
Al C
lifestooshort81 is offline   Reply With Quote
The Following User Says Thank You to lifestooshort81 For This Useful Post:
oh'mike (02-14-2013)
Questions about mosaic tile for shower floor darsunt Remodeling 6 01-12-2013 10:48 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Installing Shower in basement jburchill Plumbing 5 05-05-2011 01:14 PM
Outdoor shower questions dalepres Building & Construction 7 03-28-2011 07:10 PM
A few quick questions about redoing a shower Swazzle Remodeling 1 08-02-2010 11:06 PM
