Installing New Shower Handle After Retile - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-04-2012, 06:25 AM   #16
DIY staff
Rewards Points: 7,174
You may only need to open the hole enough to expose the mounting holes for the screws.
xelaw (08-04-2012)
Old 08-04-2012, 12:31 PM   #17
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Took the words right out of my mouth.
You may even be able to simply drill holes where the mounting holes are at. Hold the cover plate up close to where it's going to go and mark the holes. I'd drill at least a half inch hole in the tile, because they can sometimes be a real booger to get lined up.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
oh'mike (08-04-2012), xelaw (08-04-2012)
Old 08-04-2012, 09:48 PM   #18
Rewards Points: 20
Thanks everyone. I don't have a wide enough bit, so I'm going to grind away the tile around the areas where the screw holes are. I'll let you know how it goes. I've been moving slow because it's a rental and I have a lot of other stuff to work on too. Wish I'd paid more attention to realize that the screw holes were there before I covered it with backer board and tile.
xelaw is offline   Reply With Quote
The Following User Says Thank You to xelaw For This Useful Post:
oh'mike (08-05-2012)
Old 08-09-2012, 01:35 PM   #19
Rewards Points: 20
I used a tile blade on an angle grinder to cut a triangle shape from the hole where the valve comes in out past the screw holes on the valve and was able to mount the plate without widening the entire hole. Also, the valve stuck out far enough to get the handle on. It just looked like it was too short because of the camera angle I was using.
I've made a horrible MS Paint drawing to illustrate. Figured I'd provide an update in case anybody else comes across this thread. Thanks again, everybody.
The Following 2 Users Say Thank You to xelaw For This Useful Post:
oh'mike (08-10-2012), TheEplumber (08-09-2012)
Old 08-09-2012, 09:59 PM   #20
Doing it myself
Alan's Avatar
Did the cover-plate go on as well?
Journeyman Plumber
Old 08-09-2012, 10:17 PM   #21
Rewards Points: 20
Yes, that's what I was talking about. What do you mean?
Old 08-10-2012, 12:33 AM   #22
Doing it myself
Alan's Avatar
Sorry, i misread your post.
Job well done sir.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 05:56 PM
installing dura rock in shower + prefab shower pan Pcw Kitchen & Bath Remodeling 0 09-25-2010 02:39 PM
Installing Bypass Shower Doors pianodude Building & Construction 2 09-08-2009 07:09 AM
One Handle Shower Faucet GLASSMAN1 Plumbing 3 02-09-2008 04:08 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
