Old 08-02-2012, 12:04 AM   #1
Installing new shower handle after retile
I just retiled my shower and left a hole just small enough for the shower handle stem to poke out. I'm not sure where to begin as far as installing a new shower handle. I thought there would be a way to mount a new handle on top of the tile, but that doesn't look like it's the case. I'm assuming I need to cut a hole to mount the trim. Do I need to match the trim kit to the cartridge brand? Here is an image of what I'm working with. Thank you.
xelaw is offline   Reply With Quote
Old 08-02-2012, 12:33 AM   #2
Thanks for the reply. Getting rid of that tile isn't a big deal. The copper pipe sticking out is 3", my phone was at an angle, so that's probably why it looks shorter.
The Following User Says Thank You to xelaw For This Useful Post:
plumber_boy (08-02-2012)
Old 08-02-2012, 01:09 AM   #3
call me E
TheEplumber's Avatar
Do you have the white plastic plate that came with the valve? That's called a rough in plate and it should be on the valve body during installation. It is a gauge for the tile work. If your hole is smaller then that plate then your too small.
Old 08-02-2012, 08:38 AM   #4
Super Moderator
That's a Moen mixer---I see two problems---you need to cut that hole larger---about 4 inches across--an angle grinder might be the best tool for that job--use a diamond blade.
The valve is to deep in the wall---to save that job ,you will need a Moen stem extension kit---
As you have learned the hard way---reusing an old mixer valve instead of replacing is not a savings at all---
Alan (08-02-2012)
Old 08-02-2012, 10:13 AM   #5
Doing it myself
Alan's Avatar
Agree with all of the above.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (08-02-2012)
Old 08-02-2012, 10:32 AM   #6
Thanks everyone. How far out does the stem need to be? I think the camera angle I used made everything look shorter in the picture. I'm at work now so I can't measure, but it sticks out at least an inch.
Old 08-02-2012, 10:35 AM   #7
Doing it myself
Alan's Avatar
The cylinder that the stem goes into should be sticking out some as well.
If only the stem is protruding from the wall then you are at least an inch too deep.
Journeyman Plumber
Old 08-02-2012, 10:41 AM   #8
Super Moderator
Every plumbing house I have used stocks the extension--it also comes with a longer chrome tube to cover the valve----
About two weeks ago a member had to open up the wall with a grinder---post was likely in the 'tile' forum----he did a neat job----let us know if you can't find the thread----someone here will find it for you.
Old 08-02-2012, 10:49 AM   #9
Thanks, I'll look for that thread.
What do I need to search for to find a new handle that will work with this valve? Moen mixer doesn't turn up much. My valve looks like the Moen PosiTemp in all of the pics I've seen. Any chance that will work?
Old 08-02-2012, 11:01 AM   #10
This is the only thread that I've been able to find about cutting the tile. It doesn't tell me much.
Old 08-02-2012, 11:04 AM   #11
Super Moderator
If it's a Positemp then all cover sets made for those will fit----call Moen--their customer service has always been very good--ask the maker---
Plane chrome ones are stocked at most Big box stores---the fancy ones will need to be ordered---
Old 08-02-2012, 11:06 AM   #12
Super Moderator
Let me see if I can find it-----exact same situation---with pictures---Mike----
Old 08-02-2012, 03:49 PM   #13
Still haven't found anything else. I've tried to be clever with my search terms. I have a rotary Dremel, a Dremel Trio, and an angle grinder. I'm assuming one of those three things will be useful. Think I need to take this question to the tile forum since it's no longer a plumbing question.
Old 08-02-2012, 11:03 PM   #14
Doing it myself
Alan's Avatar
Angle grinder is probably your best bet, however, if you have the trim, i'd recommend putting up some tape over the general area, hold up the cover plate approximately center, and trace a line around it so you know where you need to stay far far away from with your grinder.
Mike mentioned above that you only need approximately a 4" diameter hole, but the line around the trim plate will give you an idea how much of an "uh-oh" will be covered in the end, as it will be difficult to make a perfectly round hole with a grinder.
Journeyman Plumber
Old 08-04-2012, 02:22 AM   #15
OK, I got the stem extension kit and the trim plate. It looks like I don't have to cut the hole any bigger. Seems like the plate can just sit flush against the tiles. If I made a hole, I don't even know what the inner part of the trim plate would go against. I looked at another shower that has part of a trim plate recessed into a hole like everyone was saying, but inner part of that plate is higher than the outer (if you were to lay it flat on a table). On the plate I just got, the inner part and outer part are level. If I needed a bigger hole, wouldn't the inside of the plate be higher than the outside like on the other plate?
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 05:56 PM
installing dura rock in shower + prefab shower pan Pcw Kitchen & Bath Remodeling 0 09-25-2010 02:39 PM
Installing Bypass Shower Doors pianodude Building & Construction 2 09-08-2009 07:09 AM
One Handle Shower Faucet GLASSMAN1 Plumbing 3 02-09-2008 04:08 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
