Installing New Shower Arm. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2012, 04:48 PM   #1
Installing new shower arm.
When I screwed in my new shower arm as far as I can by hand it points up at about 1 or 2 o'clock rather than down at 6 o'clock. Can I tighten it that far without breaking something? And what type tool should I use?
JBauder is offline   Reply With Quote
Old 06-23-2012, 05:31 PM   #2
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
be careful , this what i came up with i use 1/2x6"nipple and coupling , tightened the coup to the nipple that is my show arm installer.Screw the show arm into the wall[ hand tight] take your new tool w/coup end to the show arm[ hand tight] this will give you more leverage and without any tool marks i use one hand near the wall to give support on the show arm
wctekkk is offline   Reply With Quote
Old 06-23-2012, 05:37 PM   #3
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
if it's so tight i would remove and use Teflon tape and dope to the end going into wall it needs to be tight but not pipe wrench tight
Old 06-23-2012, 05:43 PM   #4
I'm sorry but I don't understand this. I looked up a 1/2x6"nipple and coupling and it looks like it would connect two female ends. Or is the nipple the "male" and the coupling the "female?" I'm sorry if I'm being dense. I used #5 pipe dope.
Old 06-23-2012, 05:49 PM   #5
Renovations contractor
Bonzai's Avatar
What he said.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 06-23-2012, 06:03 PM   #6
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
6" long nipple 1/2 in size tightened a 1/2 coup to nipple
Old 06-23-2012, 06:09 PM   #7
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
1 -screw tool to arm 2- one hand on show arm the other on tool and spin
Old 06-23-2012, 06:18 PM   #8
OK here are some changes. I calculated the number of degrees wrong and the position of the arm. It's actually point to almost 3 o'clock and needs to point down to 6 o'clock so it is off by about 90 degrees.
Old 06-23-2012, 06:20 PM   #9
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
perfect
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
installing dura rock in shower + prefab shower pan Pcw Kitchen & Bath Remodeling 0 09-25-2010 01:39 PM
Installing a Shower Blaze25 Plumbing 2 10-13-2008 07:32 PM
installing multiple shower heads jimmy21 Plumbing 5 07-02-2008 08:46 AM
installing lights in shower stall mcvane Electrical 2 03-30-2007 05:34 AM
