-   -   Installing New Gas Range (http://www.diychatroom.com/f7/installing-new-gas-range-7601/)
TonyD 04-06-2007 10:46 AM
Im installing a new gas range in a remodeled kitchen. the gas line Im tapping into is a 3/4"....when I bring the line up from the basement should or do I need to reduce it to 1/2" and then install valve.
Any info appreciated.
Tonyd
Ron The Plumber 04-07-2007 11:29 AM
If the inlet is 1/2" at the stove then yes, 1/2" is all you need.
TonyD 04-08-2007 02:41 PM
Yes the inlet at the stove is 1/2"
Thanks for the info Ron..I can always count on you for an answer.
TonyD
