Old 10-01-2009, 03:38 PM   #1
Default Installing new flush kit in commode
My big problem is: I can't get the old one off.
I have used pliers, liquid wrench, and everything I can think of. Any suggestions?
2poor2hire is offline   Reply With Quote
Old 10-02-2009, 12:14 PM   #2
If you are referring to the fill-valve, remember that the nut is upside down and it is easy to attempt to turn it in the wrong direction.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-04-2009, 10:29 AM   #3
Get a Dremel Moto Tool (tm) or similar and cutting disks (these are typically about one inch in diameter and very thin). Cut slits into the offending nut and/or pipe until these break apart.
Hint: Hold the tool firmly and carefully so the disk cuts a straight slot. Sideways pressure will cause the disk to shatter, although you usually buy the disks by the dozen for quick replacement.
Hint: For cutting plastic, go no more than about five seconds before withdrawing the disk and letting the work cool down. Otherwise the disk will freeze in the slit or shatter here too.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
More On This Topic
Dremel Tool & Wax Sculpture
Dremel Tool & Wax Sculpture by Expert Village
Okay, now you can see that we have basically the face shaped. We haven't worked too much on the forehead yet and this is kind of rough. The next thing we're going to do is we're going to approach the hair and in order to speed things up and to show you... Read More »
Hi, I'm Jason. I'm shooting on behalf of expert village dot com today. Were making beaded necklace out of recycle material. We just got done smoothing the edges on the black beads and as I said before were going to do the charm. The charm has a sharp... Read More »
Hi, I'm Jason with Expert Village. Today, we're making a charm out of rock. We're going to polish it up and make a charm for a necklace. We've already chipped off a piece of rock and there's a couple of things you need to know before we start actually... Read More »
Hi i'm Karl James owner of Creolesoul Catering located in Round Rock, Tx and on behalf of Expert Village i'm here to show you a chicken marsala recipe. Now at this point were going to take our shallot and peel this and cut this. You do have an option if... Read More »
Another tool that you can use for your dog's nails, a dremel. This is just a dremel that you would buy at a hardware store. There are several tips that you can use. I like to use the sandpaper tip for the dog's nails. This kind of finishes it off, and... Read More »
installing patio door when exterior wall out of plumb charliebrown314 Building & Construction 0 07-06-2009 03:01 PM
Installing pergo, have a vinyl underlay issue jyffmguy Flooring 1 06-06-2009 07:06 AM
Flush mount an outdoor load center? wmldwilly Electrical 1 04-29-2009 09:17 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 09:48 PM
commode air locking? mikim Plumbing 3 05-07-2007 06:21 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
