Old 02-24-2012, 05:33 PM   #1
Installing a New Dishwasher and Fixing Undersink Plumbing
Hello Everyone!
I am picking up a new dishwaher soon and am going to instll it myself. I am not concerned with hooking it up to the electricity or water, but I have some concerns about the drain connection. My home inspector told me that the old dishwasher drain was hooked up to the wrong place in the undersink plumbing and needed to be changed.
I have attached some photos of my current plumbing set up, I have two sinks and do not have a garberator. The Inspector told me to hook it into the horizontal section of pipe located just to the left of the pea trap. Do you think this is the best way? I have had some friends say that the whole plumbing system down there is a mess and I should totally re-do it, but I don't think they really know what they are talking about.
If anyone can comment on where I should hook the drain in, and what tools and materials I will need I would greatly appreciate it!
Installing a New Dishwasher and Fixing Undersink Plumbing-plumbing1.jpg   Installing a New Dishwasher and Fixing Undersink Plumbing-plumbing2.jpg   Installing a New Dishwasher and Fixing Undersink Plumbing-plumbing3.jpg
tdlewis is offline   Reply With Quote
Old 02-24-2012, 05:45 PM   #2
Could have been done with at least 1/2 the fittings they used and have far more usable room under there, I'd also replace those Quest supply lines with stainless steel flex lines.
http://video.search.yahoo.com/search...n+installation
Old 02-24-2012, 05:56 PM   #3
With the DW drain attached where it is, the DW is not behind a trap. Maybe a code violation, since every fixture is supposed to be behind a trap...?
You could definitely redo all the drains and make it much cleaner. Also, one thing that maybe a concern is the pipe where the DW drains into... The way it ties in looks a lot like it used to be the vent for that drain. I hope whoever installed it didn't cut the vent line. No vent on the sink drain would be a big no no and a serious health hazard as well.
JeepNick is offline   Reply With Quote
The Following User Says Thank You to JeepNick For This Useful Post:
plummen (02-25-2012)
Old 02-24-2012, 06:05 PM   #4
Ya that is the vent, I know it's not supposed to be hooked into there, and when I install my new dishwasher I want to hook it up correctly. The vent isn't cut it still acts as a vent for the kitchen sink, it just also has a dishwasher drain hooked into it.
Old 02-24-2012, 06:41 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Go to your local menards or whatever you have and buy an install kit for a double bowl sink to start with to make life simpler,tell them you need the fitting to instalol a disposal also.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-25-2012, 12:43 AM   #6
How is it still venting the sink if its capped? Or is there a studor vent on there somewhere? The picture isn't too clear.
Old 02-25-2012, 01:28 PM   #7
plummen's Avatar
It seems as though the plumbing is being vented through the dishwasher in his current set up
Tags
dishwasher, drain, plumbing
