Installing New Dishwasher - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 1 Post By BlackTiger
  • 1 Post By MTN REMODEL LLC
  • 2 Post By tommyxv
Old 01-08-2017, 05:03 PM   #1
Rewards Points: 117
The old dishwasher (installed by the previous owner) was a direct 3/4" connection from under the sink to the 3/4" connection on the dishwasher.
The new dishwasher tells me to use the 3/4 to 3/8 brass elbow on it. So I bought a braided SS dishwasher hose kit from HD. All good there.
The line that feeds the dishwasher (3/4 tee off of the 1/2 pipe that feeds the sink) never had its own shut valve. The valve for the hot to the faucet did both so I installed a 3/4" shut off for the dishwasher.
Then I installed a 3/4 to 3/8 adapter off the new valve.
Will going from 1/2 (feed coming up from the basement), to 3/4" then down to 3/8" cause any problems like too much water pressure to the dishwasher?
I keep picturing when you put your finger on a garden hose to spray water. LOL
See Pics! Thanks!
Installing New Dishwasher-img_20170101_001219.jpg   Installing New Dishwasher-img_20170101_115737.jpg   Installing New Dishwasher-img_20170102_115609.jpg
tommyxv is offline   Reply With Quote
Old 01-08-2017, 05:52 PM   #2
Rewards Points: 268
Re: Installing New Dishwasher
Looks fine, nice work. The larger valve won't give you any trouble.
Just to be pedantic and correct your terminology, what you're looking at is a 1/2 tee with a 1/2" female adapter, with a 3/4x1/2 reducing nipple which your 3/4" threaded ball valve is on. :P You certainly could have removed the 3/4x1/2 and used a 1/2" nipple and a 1/2" ball valve, but there's nothing wrong with what you did. The price difference of the smaller valve but buying a nipple would have probably been about the same.
tommyxv likes this.
BlackTiger is offline   Reply With Quote
Old 01-08-2017, 05:56 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,834
No.... The water pressure is the same.
SHR Plumber likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 01-08-2017, 06:05 PM   #4
Rewards Points: 117
Thanks for the replies. Glad to know that will work fine. Thx.
Old 01-09-2017, 10:47 AM   #5
Rewards Points: 1,596
Just curious, was that a gas valve that was newly installed?
bob22 is online now   Reply With Quote
Old 01-09-2017, 10:58 PM   #6
Rewards Points: 117
Its a Watts 3/4 in. Brass FIP x FIP Full Port Threaded Ball Valve.
This 3/4 in. 2-piece full port lead free ball valve is used in residential and commercial potable water applications, suitable for a full range of liquids and gases.
http://www.homedepot.com/p/Watts-3-4...V-3C/205888734
The Following User Says Thank You to tommyxv For This Useful Post:
bob22 (01-10-2017)
Old 01-09-2017, 11:03 PM   #7
Rewards Points: 117
Got the dishwasher and new air gap installed today. The old one did not have an air gap or a high loop. An air gap is required in DE.
Anyway, ran the dishwasher and no leaks! Next project!
TheEplumber and BlackTiger like this.
Considering Replacing Dishwasher Solidify Appliances 27 01-08-2015 07:08 AM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Dishwasher circuit tripping magnolia Electrical 5 10-29-2010 09:59 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 09:55 PM
Installing a 24 in. Dishwasher in 28 in. Cabinet. coreprat Appliances 3 02-19-2008 11:48 PM
