Installing New Bathroom Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-13-2008, 03:28 PM   #1
Installing new bathroom faucet
Hello
I am installing a new bathroom faucet.
Now I am istalling the valve body. The instruction say to make sure that the Valve Stems are set in the CLOSED Position. How do I do this?
I have attached that portion of the directions.
Sorry I had to put it sideways to make it big enough to see and meet the reqs for upload.
Thanks for your assistance
Cathy H
CathrynH is offline   Reply With Quote
Old 01-13-2008, 03:41 PM   #2
Send a message via AIM to Marlin
Turn the valves all the way to the right.
Marlin is offline   Reply With Quote
Old 01-13-2008, 03:44 PM   #3
Are the valves label with a hot(H) and cold(C)?
redline is offline   Reply With Quote
Old 01-13-2008, 03:46 PM   #4
Eibwen
Just slide the handle on valve temporarily and turn it clockwise til it stops.
Just as if it were already installed and you were turning the water off.
That way you know how to position the valve when you tighten it up from under the sink so that the handles look normal when your done.
Then you can reposition the handles after the valve is installed on the sink so they look right.
Sammy is offline   Reply With Quote
Old 01-13-2008, 03:50 PM   #5
Thank you, I turned them all the way to the right.
Yes, the hot is marked with red tape underneath, and I am putting it on the left.
Cathy
Old 01-13-2008, 03:56 PM   #6
Thanks Sammy
That makes good sense. I'm off to the races now!
Old 01-13-2008, 04:40 PM   #7
Eibwen
Woo Hoo!
Good luck!
Old 01-13-2008, 11:00 PM   #8
Master Plumber
Rewards Points: 150
Well I guess I shouldn't have been watching football today and having you guys misinforming the lady...looks to me like lever handles and the cold will close in the opposite way (counter clockwise)
Only some brands allow you to reposition the handle after tightening the stems down, only stems with splines would work to my knowledge and then still may be a little off
jpplumber is offline   Reply With Quote
leaky bathroom faucet; how do I change washer yummy mummy Plumbing 21 01-28-2012 01:13 PM
Installing a stackable washer dryer in hall closet next to bathroom uncleb23 Plumbing 2 10-04-2007 07:51 AM
Replacing bathroom faucet but unsure which type it is phaze112 Plumbing 3 10-03-2007 04:09 PM
Installing a new kitchen faucet... fp1 Plumbing 2 01-08-2007 06:02 PM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
