Installing Multiple Shower Heads - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2008, 11:20 PM   #1
liscenced electrician
Rewards Points: 538
installing multiple shower heads
im building a house on a budget, and i would like to have 2 or possibly 3 shower heads in our tile shower. Is there a cheap way to do this? Could i just use a standard hot/cold mixer and then T it off and go to 2 volume controls and then the shower heads?? I want to do this on a budget but i don't want my install to be "ghetto"
thanks
jimmy21 is offline   Reply With Quote
Old 07-01-2008, 11:32 PM   #2
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Jimmy, it really depends on the maximum flow rate of the faucet you use. As a rule of thumb, figure 2.5 GPM (gallons per minute) for each shower head. Most codes require 2.2 GPM or less, so 2.5 allows a little margin. Many "standard" mixing valves, which need to be either thermostatic or pressure balancing to comply with code, won't flow enough water for 3 shower heads. You may need to go with either a higher priced valve or 2 lower priced valves. Just check the technical data on the valves you are planning to use. This should be available on the manufacturers website.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 07-02-2008, 01:30 AM   #3
Rewards Points: 538
so what if i just went with 2 heads? and would that be the way to do it, providing the data on the mixer checked out?
Old 07-02-2008, 08:12 AM   #4
mstplumber's Avatar
Rewards Points: 150
Yes, that would work, as long as the valve will supply enough volume. Depending on what brand fixture you want to use, it might cost more to use a mixing valve and separate volume controls than to get one of the "combo" type valves or one that uses a single diverter valve to manage different functions. Both Moen and Delta, for instance, offer valves that will allow you to supply multiple outlets from a single diverter valve. Moen even offers one that is all built into one valve, called the 3 function Moentrol. Again, check the maximum flow rate.
Mstplumber
Old 07-02-2008, 09:35 AM   #5
Rewards Points: 1,910
Also check into what size drain you'll need to handle the extra water volume.
Old 07-02-2008, 09:46 AM   #6
mstplumber's Avatar
Rewards Points: 150
A standard 2" shower drain will be plenty big enough for 3 shower heads @ 2.5 GPM. A 2" trap is usually rated at 3 Drainage Fixture Units (DFU), which translates to about 22.5 GPM. (1 DFU = 1 cubit foot of water per minute =7.5 GPM).
Mstplumber
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Installing a Shower Blaze25 Plumbing 2 10-13-2008 08:32 PM
Installing a shower pipe (again) donvier Plumbing 14 02-04-2008 10:06 AM
Installing a New shower facuet... BDPNA Plumbing 8 01-18-2007 09:23 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 09:26 AM
