Installing In-Line Shutoffs In Copper Waterlines - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2012, 01:41 PM   #1
Installing In-Line Shutoffs in Copper Waterlines
I need to install inline shutoff valves in 1/2" copper waterline. I have two of them. I have never sweated pipe successfully. I am having trouble locating straight compression valves with both ends for 1/2"ID (5/8"OD). My local plumbing supply says they don't carry any compression
valves. I was shown a Shark Bite Ball Valve but it sure seems a bit bulky. (See pictures below.)
Once the valves are in I can replace that sink. All suggestions appreciated.
crashdavid is offline   Reply With Quote
Old 08-13-2012, 11:27 PM   #2
Hi David,
A quick search on-line revealed that HD carries what you're looking for. I'm surprised that your local plumbing supply doesn't carry them, I guess that there's not much local demand.
VIPlumber is offline   Reply With Quote
Old 08-13-2012, 11:38 PM   #3
Rewards Points: 14,300
A Shark Bit by far would be the simplest way to go.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
crashdavid (08-14-2012), jaydevries (08-14-2012)
Old 08-14-2012, 08:24 AM   #4
Originally Posted by VIPlumber View Post
Hi David,
I had refrained from posting my question on this forum until I had gone through all 321 valves on the HD pages several times; until I had gone to HD and found their most knowledgeable plumbing associate; until I had gone to my local plumbing supply house; until I had cleaned up the pipes and taken and edited pictures to post with my question. I tried to do my homework.
Could you please be a little more specific?
Old 08-14-2012, 09:11 AM   #5
Rewards Points: 264
Is it important to have a shut off there? You need to turn the water off to install one, so why not just turn it off, replace the faucets and be done with your end goal? If you don't like sweating copper just go with the shark bites. There are a ton of threads here on them, too simple to seem legit but they work just fine.
moneymgmt is offline   Reply With Quote
Old 08-14-2012, 09:23 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
http://common1.csnimages.com/lf/49/h...090471/1/1.jpg
2x http://www.homebuilderwholesale.com/...0/00324967.jpg
= WIN
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 08-14-2012, 10:03 AM   #7
Thanks. Isn't it standard good practice to have shut offs on all plumbing fixtures and faucets?
Old 08-14-2012, 01:36 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 904
Yes, and a code requirement in my area although not strictly enforced, ie tub/shower valves.
In your case, I'd kill the house supply and forget the valves
Old 08-14-2012, 02:14 PM   #9
Shut Off Valves
Thanks to all. I will let the next owner put in the shut off valves.
Old 08-14-2012, 04:46 PM   #10
biggles's Avatar
is the hot/cold coming from those lower right pipes..putting the valves there would shut everything to the left of them including the sink if they are the supply lines from the city/cold and HWH
Old 08-14-2012, 05:17 PM   #11
framer
how do you ground a house with PCVC
elpreacher is offline   Reply With Quote
Old 08-14-2012, 07:25 PM   #12
Thanks for asking. No, those 2 pipes actually go to the right out to the clothes washer. Those two pipes have shut off valves at the end.
Old 08-14-2012, 09:01 PM   #13
Doing it myself
Alan's Avatar
My code calls for valves only ahead of each water supplied appliance, or a slip joint supply.
Hard piped items like shower valves don't need them.
(this aside from a main building shutoff, of course)
Journeyman Plumber
Old 08-15-2012, 09:53 PM   #14
http://www.homedepot.ca/product/ball...ression/959951
The Following User Says Thank You to VIPlumber For This Useful Post:
crashdavid (08-16-2012)
Tags
compression , copper , inline , shutoff , valves
air conditioning leak in insulated copper line, in attic? johnfrmsport HVAC 3 07-18-2011 05:40 PM
Copper or PEX for exterior water line replacement 205bhamjim Plumbing 1 06-13-2010 07:40 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
Flexible copper gas line wease Plumbing 6 04-09-2008 10:40 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 08:19 PM
