-   -   installing a lav sink without clamps (http://www.diychatroom.com/f7/installing-lav-sink-without-clamps-158857/)
hellonoko 10-03-2012 03:22 PM
I am replacing a lav sink in my bathroom.
I think this is the model of the new one: http://www.wayfair.com/superbrowse.p...=4998227&img=1
It is a drop in sink but it has no clamping mechanism of any kind on the underside.
The old sink I removed and my new sink in another bathroom has clamps that hold it in place.
Should I return this sink and get one that clamps or otherwise what is the correct way to install this sink and make it stay in place?
DannyT 10-03-2012 03:28 PM
what do the instructions say to do? most drop ins like that need to be glued down. the ones i used to install came with a small tube of adhesive. because i couldn't come back the next day i used to either glue them and set something on top of them so they didn't move while i connected the drain and waterlines or i would connect everything and then glue them down. there was enough give that i could lift them up slightly and squirt the adhesive under the edge. in your case i would glue it down and then connect it the next day.
hellonoko 10-03-2012 03:32 PM
@DannyT - instructions say to 'apply sealant' but it had none included.
I may just return it and get one like my other one. It seems like having it clamped and glued down is a much better solution.
