Installing Interior Drain Tile - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2008, 11:41 PM   #1
Installing interior drain tile
I have a crawl space (gravel floor) and I am getting the heavy plastic liner to seal out the moisture. I would like to install a drain tile myself and was wondering if anyone has detailed instructions how to do this. It seems pretty easy, but want to make sure I am not missing anything. I have a sump alreayd in place.
Tim
timchi29 is offline   Reply With Quote
Old 10-05-2008, 12:47 AM   #2
Registered User
Termite's Avatar
Interior drain tile I assume? First, make sure you have an outside drain. That's the most important one, and is where I'd focus my efforts if you have neither.
Either way, the drain needs to be at the level of the footing to be most effective. Be careful not to undermine the footing by disturbing soil under it or within the 45 degree load path of the footing. Install perforated drain (in a drain sock is even better) around the perimeter. It must be very level, or slightly pitched toward the sump pit. It must enter the pit at the same level or lower, as water won't flow uphill. The drain needs to be basically surrounded with gravel, and covered with no less than 6" of gravel.
Old 10-05-2008, 09:18 AM   #3
thanks. I have gotten 2 quotes so far and they both said it will be a couple inches below the existing grade of the floor. One contractor is proposing a new concrete floor and the other a 20mil liner.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Installing tile and wood- what order? red shoes Flooring 7 05-08-2008 06:34 PM
Installing porcelain tile on a sloping floor Wanttodoitright Flooring 11 03-20-2008 02:37 PM
Installing Laminate in Kitchen/Ceramic Tile in Hallway ssutton3014 Flooring 1 10-18-2007 12:18 AM
Installing Ceramic tile: Ditra over Vinyl or rip out and use 5/8 Plywood? ppieda Flooring 2 10-05-2007 12:01 PM
