Installing A Hot / Cold Water Spigot - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-25-2008, 03:31 PM   #1
Installing a Hot / Cold Water Spigot
My parents recently had a plumber install a hot / cold water spigot as well as a separate cold-water only spigot. I was so impressed with the idea of using hot water outside so I have decided to install one of those hot/cold units in my house.
The plumber had used a white nylon flexible hose for the cold water-only spigot. Are any of you familiar with that flexible water hose and what the fittings look like?
The spigot at my house will be installed roughly 20 feet away from the main copper water lines. My idea for each line is to solder in T fittings, install ľ turn shutoff valves, then run that flexible hose the 20feet to the spigot. Iím thinking that I can save money using that hose versus the copper tubing. There will probably be fewer joints that I will need to worry about if I use the hose.
The only other challenge will be drilling a hole through the concrete brick trim wall we have in front of the house. Iím checking with our maintenance department to see if they have a masonry bit so I wonít have to buy one.
Please let me know your thoughts about that hose and about my plan so far.
dc2295 is offline   Reply With Quote
Old 02-25-2008, 05:10 PM   #2
Go for it. There was an mention of hot/cold spigots in this month's issue of This Old House magazine. The pipe the plumber used was probably PEX. The pipe is cheap. The fittings and tools to install are not as cheap. The Lowe's in my area carried everything needed for it.
jerryh3 is offline   Reply With Quote
advice on cold water pipe in basement garage area cambie Plumbing 6 10-15-2008 01:29 PM
Cold water pressure low Showerpower Plumbing 2 01-20-2008 07:25 AM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 06:20 PM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 08:02 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
